This command displays configuration and status information about the specified IS-IS interface.
enabled | Displays information only for IS-IS-enabled VLANs. |
vlan_name | Specifies a VLAN for which to display IS-IS interface information. |
all | Displays information on all IS-IS interfaces. |
N/A.
None.
The following command displays IS-IS interface information for the SJvlan VLAN:
show isis vlan SJvlan ISIS Interfaces Summary : ------------------------------------------------------------------------------ VLAN Area State Cfg Address ------------------------------------------------------------------------------ v2 a1 u46-- p1246 2.1.1.2/24 2001:db8:2010::1/64 v3 a1 u46-g p1246 2001:db8:2011::2/64 State Flags : u - Links up, d - Links down, 4 - IPv4 forwarding enabled, 6 - IPv6 forwarding enabled, n - Multinetted (v4), g - Multiple global addresses (v6) Cfg Flags : b - Broadcast interface, p - Point-To-Point interface, 1 - L1 circuit type, 2 - L2 circuit type, 4 - ISIS-enabled for IPv4, 6 - ISIS-enabled for IPv6
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
